Hello,
I am currently receiving this error every so often. When the machine is rebooted the SATA hard drive is no longer detected in BIOS and the hard drive is still spinning normally, which I think means something is up with the hard drive. The optical PATA drive and floppy drive are detected normally, and so is every other piece of hardware. After switching the machine off at the power supply for around a minute makes the hard drive detectable again and everything works fine for the next day or two. Placing the hard drive on a differant SATA channel with a differant power and data cable still gives the same problem after a while. SMART status is not running at optimum condition too. I am also using default Windows x64 IDE drivers. The hard drive is about three to four years old and I think it may be seeing better days, but I am not really experiencing any data loss at all.
I am planning on buying new memory and a hard drive which I hope will rectify this problem and although it seems I have all the bases covered, I would like anyone's opinion on this problem hopefully putting my mind at ease.
Thank you.
Thank you.
