Macro shots - comments please!
DRZ
DRZ
2 Jun 2003
In the top 1%
Some from this week! :)
All taken with my Sigma 105mm Macro and 430EX. For some (Definitely the ant shot, not sure about some of the others) I used stacked Kenko extension tubes.
This was physically the most demanding 'shoot' I have ever done - the heat / humidity was almost unbearable and my clothes were wringing wet afterwards!
They were taken in a place called Butterfly World in Edinburgh.
All the details are in the exif data, but I used a Sigma 105mm Macro, 430EX and a 300D
Yeah, my sensor is getting to the "too dirty to continue" stage (for macro work at least).
It is getting cleaned tomorrow though :)
The turtle image could do with being cropped, the large empty space on the left side is unnecessary.
I think the ant photo would have looked better from underneath with it's jaws in focus.
Do you do the cleaning yourself? Is it a frequent necessity? Is it costly?
I really like your photos, in my opionion the two you initially left out are the best.
Did you use a tripod, monopod, hand held or a combination?
Great work and the results must be worth the effort!
I tried and it seemed to look unbalanced, so I cropped it that way instead. Maybe I just did it badly - im still learning! :)
The ant was unfortunately on the bottom of a glass-walled tank thing, impossible to get at it from any other angle really (I was getting funny looks just leaning over the glass!)
Should I be pleased that someone as good at photography as you only had those things to say about them, or a little bit disappointed? :p
@Belly All of them were handheld! Cleaning isnt something you really have to do often and only costs a few quid to buy the stuff to do it. I am meeting up with a few of the people on here tomorrow in Liverpool and Lostkat kindly offered to do it for me / show me as I have never done it before - having owned the camera for about a year.
Any criticism aimed at improving one's performace is praise in itself! Of course the real lessons learned in life are the ones in which you made mistakes to begin with - you always remember those and try to correct them in future. I think lots of members give good critical advice, but some unfortunately belong to the "Mutual Back-Slappers Society" and who would gladly accept such praise?
Real criticism should be aimed at people who do nothing! Don't be disappointed, wear it like a medal!
Thanx for the info on cleaning. I'll try and read up on the subject before buying a DSLR
Amazing shots, the ones that really caught my eye were the first and last ones, they just really seem to have some, well, 'oomph' i suppose.
