Magnets on your oil Filter?
Nickg said:
hi guys, just read about magnets being applied onto oil filters - basically will keep and hold any shards of metal which happen to go through the filter which may have made it back out again!
quite novel, yet fantastically simple idea. anyone use it?
http://www.carbibles.com/engineoil_bible.html
Not really new to be honest. Some manufacturers have been making the sump drain plugs magnetic for years.
I would be more worried why any metal particles made it through the filter.
I also have to wonder how much of the metalic debris he found when he cut open his filter, where actualy caused by cutting open his filter...
good point, the swarf is only going to be fine grains of metal...the same that are generated by sawing a metal filter in half, lol.
Aye, I've got a filtermag which comes with me between cars, seems to work quite well.
If you're concerned, a good budget alternative is to get a decent rare earth magnet or similar and clip or tape (if alloy) it or place (if iron or steel) it on your sump to retain any debris :)
i should hope not!
the bits that wear are usually hard metal, the pistons and heads are ally because they shouldn't be wearing parts. the piston shouldn't touch anything but its rings and the little end.
th e problem with magnets on oil filters is that it turns small debris into big magnetic clumps, a bit of oil pressure later and you could have a clump of debris making its way around.
sump plugs are different because they sit at the bottom and any bits that come off should resettle thanks to gravity.
edit-this reply was too simon but i spent too long typing :-(
Ah right, I wouldn't know anything about engine wear to be honest. ;)
Not heard of piston rock? The piston is on a pin, it doesn't stay perfectly vertical
I don't know about cars but in my Ducati 750SS twin the pistons most certainly do not touch anything but the rings and the small end bearing.
They may move side to side but they sure as hell don't touch the bore. I thought the whole point of the rings is to accomodate this movement without the piston needing to come in contact with the bore and to seal the resultant gap needed to allow this to happen.
In the latter stages of the war, the Germans (so I've read somewhere) used to attach magnets to aircraft engines, the logic being that any subsequently damaged & shot up engine, may stay running (as the magnets attract bits of damaged engine away from the still moving parts) for a little while longer (which could be the difference between life & death)
Can't recall if it was a book or the web, I'll try & find the source.
