Last night i came back to see a STOP Check error on my PC Monitor (BSOD)
Restarted the PC, to find 'Disk Boot Failure' appear.
The disk is a WD5000AAKS model. Checked the BIOS, and the drive is now not listed. I have a secondary 500gb disk, and this is showing fine. The main disk has the OS and all my important data.
I have changed cables on the mainboard connecting the disk, with no change. I tried connecting this disk on a laptop using a usb/sata caddy, and Windows did not recognise the drive either.
When starting up, the drive spins up for a few seconds and then spins down without any further activity.
Im dreading the worst, but is there anything else i can try to at least retrieve the data on this disk?
I hope it was nothing vital, otherwise your only choice is data retrieval really (other than trying another PCB but that is hit and miss).
