http://www.electrisave.co.uk/
Are these available in the uk yet ? will we be finally to dispell the myth of power requirements for our pc's ? here's one such quote from a user that has purchased one of these and done some tests.
This intelligent power meter simply plugs into a normal power point (GPO) and turns it into a real-time power monitoring outlet. You can enter the local price of your electricity and the meter will tell you exactly how much the appliance is costing to run. In addition, the power meter tracks the power used and can display the instantaneous voltage or current being drawn as well as the peak levels that have been drawn. The meter has backup batteries so it will not lose the stored data during a blackout or moving from point to point. Simple to install and a valuable tool for monitoring power consumption.
because i was curious on my power usage with my pcs and was pretty amazed at it
e6600 @ 3.8ghz w/ 8800gtx @ 675/1050, 150gb raptor, sblive, corsiar 620w = 340 under fullload (3dmark)
e6300 @ 2.5ghz w/ onboard x700, 8x750gb wd, 2x 500gb seagate, xfi extreme music, areca 12-20 raid card, Thermaltake 750w psu = 320w under full load (copying files+3dmark)
was rather intereseting
and then had my 42' lcd @ 260watt (how much the e6300 is at idle)
and dell 24' @ ~ 40w with a coulpe things plugged in.
