major problem
28 Jul 2007
Sunderland
hi all iam posting this for a mate who lives abroad, his just done a new build and this is whats happening to him
Alright, so heres the deal. I've connected the entire PC with the cables and so on.. I start the bugger up and it runs fine. Now, Problem: After 20-30 secs it just stops (ie shuts down).
List of specs:
Motherboard: EVGA nForce 650i Ultra 775 T1
Ram: Corsair XMS 2 DDR (4 sticks x 1 GB)
CPU: Intel Core 2 Duo
GPU: Gainward BLISS 8600 GTS PCX Golden Sample
PSU: Corsair HX520W
HDD: Samsung 500GB 3.5"
DVD-ROM: NEC
The deal is, I've checked without the GPU, some of the RAM sticks and the HDD and DVD, and it still doesn't work. Hence, I reckon it's the Motherboard that isn't working
Also, I got it working once, by clearing the CMOS, but after reattaching the HDD, the DVD, and the rest of the ram (only used one of the sticks) I went back to the same problem
all help will be grateful ;)
1. Check all your power connectors to the motherboard
<retry>
2. Check the CPU HSF (heatsink and fan) is correctly fitted, sounds like it is overheating to me. Take it off, and put it on again.
<retry>
i've spoken to the person concerned and hes confirmed it was the heatsink causing the problem, been seated properly and the thing is working.
