Hi Folks,
(Mod I do not know where to post this thread so I posted here in seek of advice urgently.)
I need your help as I have been trying to get my new build to work for more than a week now. I would greatly appreciate if you could explain in detail (down to minor detail) as to the steps I should take. Please assume you are teaching someone with no PC building knowledge.
As this is my first build please help me by providing exact explanation or as clearly as possible by not ignoring or assuming that I know the process of installation. Each time when I encountered a certain jargon I had to do plenty of reading before I proceed and so far I have been having sleepless night ...
My first attempt to build my system has encountered major problem now and I will explain below.
This is my sepc:
1) Win 7 Home 64bits.
2) Gigabyte GA-P55M-UD2
3) 80GB Intel SSD.
4) Corsair H50 water cool
5) Lian Li V351R case.
Intention of my build.
1) 1st disk - 80GB Intel SSD - mainly for Win 7 64bits OS only.
2) 2nd disk - 1TB Samsung F3 - not connect up yet - this drive will be used for data storage or perhaps future dual boot with Linux.
My progress so far (not connected to internet yet):
1) All hardware in place.
2) SSD set to AHCI.
3) H50 installed appropriately (reading from BIOS CPU temp is around 28C - 30C)
4) H50 fan - from BIOS reading is around 1092 ~RPM.
5) Installed Win 7 64bits.
6) Installed Office package.
5) Downloaded mobo drivers (Version 1.1 - the latest) to USB stick from Gigabyte website as I was advised the CD/DVD might be old.
The following major problems have surfaced now:
1) while updating drivers my first attempt to extract zip (USB stick straight to C: by clicking Setup on the .exe file - i.e. not extract to C: then double clicked on Setup) went wrong as one of the file was not extracted properly so I reinstalled, many times, on all of them again so I am not sure the present problem I have now is related.
2) System hang many times but eventually it repaired and I was able to log on to Windows.
3) Today it hang again so I reinstalled all the mobo drivers as it was only displaying the Window 7boot page but not going further.
4) After reinstalling all the downloaded mobo drivers ... it eventually starts to boot up properly but then more problems encountered:
4i) now whenever I am in Windows I always get this message:
"Do you want to allow the following programme to make changes to this computer?
Gigabyte RAID configurer
JMicron Technology Crop
Hard drive on this computer"
I have to click "No" but each time when I boot into Windows the same message appear.
5) I noticed one of the case fan (Akasa Apache 120mm) 4 pins connected to the SYS_FAN header is not spinning at all so I thought it was normal since the temperate might be low so I let it be. The other fan (same model) for the H50 is spinning slowly and it is connected to the CPU_FAN.
So I thought I should check the temperature and I entered BIOS - PC Health Status - only to notice that the CPU fan is spinning but not the System Fan which I have connected to one of the case fan.
Then I thought I needed to enabled all features available for the fans and I did this:
- CPU warning temperature [80C/176F]
- CPU Fan Fail Warning [Enabled]
- System FAN Fail Warning [Enabled]
- CPU Smart Fan Control [Enabled]
- CPU Smart Fan mode [PWM]
Restart / reboot ...
Now, the computer keep giving me loud buzzing warning sound and I immediately disabled and enabled the above CPU & Fan control accordingly to find the problem and I found ... the problem coming from the "0" RPM speed of the System FAN ... i.e. when I disabled System FAN Fail Warning the buzzing stopped. So I know this is the problem but not sure how to solve it since the mobo should be able to run the fan.
Help and advice please on the above or the followings:
1) How to solve/get rid of the "JMicron Technology Corp" popping up each time I am in Windows?
2) How to solve/get rid of the SYS_FAN buzzing noise as it is not doing it's job at the moment because the fan is not spinning? It tried to spin occasionally but failed.
3) How to make sure all the mobo chipset drivers are installed properly?
4) Do I need to rebuild the system from scratch again?
Please help ....
This is my sepc:
3) 80GB Intel SSD.
2) SSD set to AHCI.
Please help ....
