Corsair Enthusiast Series TX550M High Performance 550W '80 Plus Bronze' Modular Power Supply (CP-9020001-UK)
having more than one (or two) 3.5" spinning rust is going the way of the dodo these days.
considered a NAS?
The p400 is a compact case, relatively.
And you won't be restricted to micro ATX motherboards.
How old is this? Could you replace it with a SFX-L PSU? And take the opportunity to consolidate your HDDs down to one. Doing both would give you many more options.
It's about 5 years old I think. It's actually a 520W.
So, now all I need is a sensible, reasonable looking, smallish, mATX
synology ds218j seems to be reasonably well recommended for a 2 bay nasAny suggestions??!
Any suggestions?will fit a longer GPU so you may find a twin fan card quieter
Lol - might have saved a bit of time@Quartz hah, yeah. not quite sure why i didn't think of a spec using a bay converter earlier!
i wouldn't bother really. gtx 1660 is a power sipping card so a single fan solution should be adequateAny suggestions?
1660 is about 10% faster than a 590
590 is £170-£180 when on sale
Ergo I wouldn't pay more than £200 for a 1660.
it is a decent looking case isn't itI like the look of the Citadel case
Any suggestions?
Also read up on NAS and have ordered one of these ^^^, plussynology ds218j seems to be reasonably well recommended for a 2 bay nas
This is due out tomorrow, so will see what happens. If nothing else, might hopefully push costs of non-super down a bit! But will order either a 1660 (+/- super) or 590 in next couple of days.Since the GTX 1660 Super has just been leaked, it's an easy wait.
just stick it on gumtreeand maybe the:
But not totally sure what I'd use if for? Just doesn't seem worth throwing it away!
- 1x Samsung 256GB SSD 830
i doubt it...i think it'll slot in 20 qud more expensive than the 1660. again at these kinds of price points (590/1660/1660ti/1660 super) it's all about the price/performance ratioThis is due out tomorrow, so will see what happens. If nothing else, might hopefully push costs of non-super down a bit! But will order either a 1660 (+/- super) or 590 in next couple of days.
think everything's about right on where i'd spec.Is there anything else I should now be looking at with my greatly reduced number of HDDs?!! If not, happy to order the Citadel.
