Making monitors better for reading
26 Jun 2009
Sheffield
I have a fairly serious problem, I find reading text on a monitor very uncomfortable. This is a problem because I'm trying to do a computing degree. I feel it's really starting to hold me back.
Not sure what to do really. I have found that black text on a light grey background is easier, so should I try reducing my backlight level?
Anyone have the same/similar issue?
what screen are you using?
could be any number of things potentially. too small a pixel pitch, poorly set up gamma or brightness, affects caused by Pulse Width modulation backlight dimming, dodgy / broken screen or cables
Hannspree HF287. I actually have 3 of them so I can compare results. :P
Playing around with zoom, sitting position, brightness etc seems to have only done so much, I still much prefer reading things on paper.
Maybe part of the problem is just me... Reading reports is boring, so focusing on paper and standing up seems to force me to concentrate more. It's a waste of paper though!
Well I doubt you're alone in that and it's often not as easy to focus on a large screen as on a good old piece of paper
You may perhaps be seeing some issues with PWM use for backlight dimming? If you've not heard of that before read the article at tftcentral linked in my sig :)
Have you tried activating clear text?
Control Panel >> Display settings >> Adjust Clear Type text
...then follow on screen instructions.
With regards easy reading, I suggest you reduce your brightness level and contrast level. This will make reading for extended periods easier on your eyes. All my monitors are set up to be very soft on the eyes (low brightness and low contrast).
Hope this helps.
Would it be worth getting something like the kindle (not sure if the kindle can be used in this fashion as its probably too locked down) to upload stuff you have to read a lot of to? i.e. ereaders that have displays designed for prolonged reading from.
Kindle would be "locked down", however, you could get a tablet PC, to remove the locks and simulate the feel of reading a piece of paper. I think tablet PCs are relatively cheap these days.
Personally though, I feel that a good/sharp IPS screen is great for text reading and as good as reading from paper.
For me, Dell U2311H is the best monitor I have owned for reading text. Its terrible for graphics/movies, but great for text.
