Many of the same BSOD. :(
- Removed GPU OC
- Removed old GPU drivers (and my screen went to 800x600)
- Removed CPU OC
- Installed new GPU drivers (it failed first time around,b ut I didn't bother deleting -> installing again, so I just installed again and it worked. Its the same thing over the same thing, now sure if it will cause damage. Screen went back to 1024x768)
I'll wait, see if I get any BSODs now. Lets give it a week. If so, I'll try OC GPU (to se if ti was the drivers)
Did you change the driver then or just revert back to stock speeds?
I did that, in that order.
GOT IT AGAIN :@:@:@:@::@
I think its because of CCC. yet I can't find how to uninstall CCC because it doesn't show in CP
EDIT: It had to uninstall the drivers too for it to uninstall CCC. Uninstalled everything and doing the drivers again :O Installing drivers won't install CCC yes?
On another PC, actually a netbook,its so slow I feel like breaking it.
EDIT 2:
Here is the BSOD error for all of you:
http://vvcap.net/db/PfiBf42znlTU8cofDA60.htp
And when I went to install the drivers
http://vvcap.net/db/o1QDONocxLnlQYqfSrPx.htp
http://vvcap.net/db/wi_ON6COvsOyiaMeiKxF.htp
And I cleaned the drivers, and I got it AGAIN! I think I'm gonna try re-install it over this corrupted version :/
EDIT 3: Installing over the broken install seemed to work. I think I am ready, until I get another ****** BSOD.
Note to self: DO NOT USE CCC :D
