Marantz CD80 replacement??
gkt
gkt
17 Apr 2018
Hi,
I am looking to buy a Cd player which would replace my Marantz CD80 player which sadly is jumping and not reading discs very well. It would seem parts for this player are non existent anymore!
I presently have Arcam Black box.. Audiolab Pre-amp...Audiolab c Amp.. Kef 104/2 speakers.
Any advice would greatly received!
Thanks.
Gary.
Hi.. thanks for the info.. its CDM1 mk2.. The philips looks as though its a walkman type!?! be great to find a donor Philips with same Transport though.. thanks. :)
Depending on what you're looking for then you might want to have a look at the ARCAM DVD/CD players - the DV27 in particular is great as a transport but also has a very good internal DAC. I really rate my Denon DVD-2900 and you can pick them up for a song now. The Pioneer DV-989avi is outstanding as a transport; this reported by a friend who has easy access to ARCAM, Accuphase and dCS.
If you do end up replacing it, don't bin/skip the old marantz even if you cant repair it. People will pay silly money for the old philips TDA1541A S1 crown dac in it.
jpauls advice is good. I did the same thing when my marantz CD56 died and used an old philips machine for parts.
Really! What would you do in my situation.. I ordered a new CD this evening...
I’d either stick the unit on eBay and see what it goes for or I’d strip it of the useful parts and build a dac using the chip with a tda1541 dac pcb kit.
