Hi there
We took a delivery this morning of several new TeamGroup memory SKU's on Xtreem and Elite series, check them out here:-
TeamGroup Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit @ £251.99 inc VAT
Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.
It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory!
Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.
- Fully compatible with Intel P67, Z68, Z77, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)
- CL-value: 10-12-12-31 1T
- Working voltage: 1.55-1.65V
- PCB: 8 layer PCB
Only £251.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 32GB (4x8GB) DDR3 PC3-19200C10 2400MHz Dual/Quad Channel Kit (TXD332G2400HC10QQC-L) @ £399.95 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 9-11-11-28 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 10-12-12-31
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Only £399.95 inc VAT.
ORDER NOW
TeamGroup Xtreem 32GB (4x8GB) DDR3 PC3-17000C11 2133MHz Dual/Quad Channel Kit (TXD332G2133HC11QC-L) @ £349.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.5V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
Features:-
- CL-tRCD-tRP-tRAS 11-11-11-28
- Data transfer bandwidth 17,064MB/Sec (PC3 17000)
- Working voltage 1.5V
Only £349.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L) @ £119.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Only £119.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-24000C11 3000MHz Dual Channel Kit (TXD38192M3000HC11VDC-L) @ £499.99 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem LV DDR3 3000 CL11. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 8GB (4GB*2) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- World First 3000MHz commercially available kit
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 256x8
- Data transfer bandwidth 24,000 MB/Sec (PC3 24,000)
- Heat Sink Yes
- Working voltage 1.65-1.75V
- 8 Layers PCB
Only £499.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-22400C11 2800MHz Dual Channel Kit (TXD38192M2800HC11RDC-L) @ £399.95 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem LV DDR3 2800 CL11. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 8GB (4GB*2) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- CL-tRCD-tRP-tRAS 11-14-14-31
- Data transfer bandwidth 22,400 MB/Sec (PC3 22,400)
- Heat Sink Yes
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-21300C10 2666MHz Dual Channel Kit (TXD38192M2666HC10QDC-L) @ £249.95 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem DDR3 2666. Intel’s latest Series Z77 chipsets. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 16GB (4GBx4) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- Data transfer bandwidth 21,328MB/Sec (PC3 21300)
- Heat Sink Yes
Only £249.95 inc VAT.
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-19200C9 2400MHz Dual Channel Kit (TXD38192M2400HC9NDC-L) @ £155.99 inc VAT
Features:-
- CL-tRCD-tRP-tRAS 9-11-11-28
Only £155.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (TXD316G2400HC10QDC-L) @ £239.99 inc VAT
Features:-
Only £239.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TXD38192M2400HC11DC-L) @ £119.99 inc VAT
Features:-
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (TXD38192M2133HC9NDC-L) @ £79.99 inc VAT
Features:-
Only £79.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD316G2133HC11DC-L) @ £229.99 inc VAT
Features:-
Only £199.99 inc VAT.
ORDER NOW
TeamGroup Xtreem 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38192M2133HC11DC-L) @ £69.95 inc VAT
Features:-
Only £69.95 inc VAT.
ORDER NOW
TeamGroup Elite 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED316G1600HC11DC) @ £83.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Working voltage 1.5V± 0.075V
Only £83.99 inc VAT.
ORDER NOW
TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38192M1600HC11DC) @ £47.99 inc VAT
Features:-
Only £47.99 inc VAT.
ORDER NOW
TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34096M1600HC11DC) @ £29.99 inc VAT
Features:-
Only £29.99 inc VAT.
ORDER NOW
TeamGroup are without a doubt one of the highest quality memory partners out there and when it comes to performance they are easily ahead of the game, we have 3000MHz arriving tomorrow in stock, thats a UK first.
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
- PCB: 8 layer PCB
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
Features:-
- Heat Sink Yes
- 8 Layers PCB
ORDER NOW
Features:-
- Heat Sink Yes
ORDER NOW
Features:-
- Heat Sink Yes
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
