- 13 Jun 2021
- UK
Hi there,
While playing Fortnite, I get really bad FPS drops. If I'm playing at 60fps, I often drop to the 40s and occasionally as low as the 20s. I've tried a bunch of things:
I'm working with a Zotac RTX3080, ryzen 7 5800X, 16gb Corsair 3600 MHz RAM and a Corsair RM850x PSU. I have a dual monitor set up with a 144Hz primary Asus monitor and a 60Hz secondary hp monitor.
Everyone I've asked is telling me it'll just be some sneaky setting that needs calibrated properly, but I'm running out of ideas.
Thanks in advance,
Josh
- update nvidia drivers
- uninstall and reinstall nvidia drivers
- lowered my Fortnite settings
- remove Discord overlay
- close all other apps apart from Fortnite
- change FPS rate (between 60 and 144)
- optimised settings in nvidia control panel for Fortnite
- tested my graphics card on Ungine and got a result that suggests the graphics card is performing normally
Thanks in advance,
Josh
