Vdroop is actually a requirement of Intel CPU specifications.
Yeah that is a bit extreme.
And as for just upping volts, it means you'll be running massive volts at idle just to get the load volts you require.
Cmon Jokester, having a constant vCore line will keep a CPU stable using less voltage and no matter what speed you are running stability and lower power consumption are both important!And did it let you overclock further?
Does that mod work on the C version of the p35 ds3r?
forgot to add the C onto mine :/
mine is the Gigabyte P35C-DS3R
