Master & Slave on Crossfire
1 Nov 2003
Maidstone, Kent
Hello,
A quick question.
I own the x1800xl card (HIS). I am saving up to get a mastercard to go with it. I just see that all the mastercards on the OC website say they require a compatable XT slave card.
I was under the impression that the x1800xl cards would work in crossfire mode with the x1800xt card as master.
As ATi are stopping production of the x1800xl range am I bu**ered or will the x1800xt mastercards work in crossfire mode with my current set up?
Thanks
Hussman.
Originally Posted by FasterThanJesus
What is the score with the stock for the Powercolor X1800XT CFs?
I want one, but would rather wait a couple of weeks rather than going back into my overdraft, but have heard that they're being phased out in favour of the new X1900s (which obviously won't be compatible with the X1800s)
answer from Gibbo
Hi m8
ATI have no more stock current and were down to approx 30 units which we expect to be all sold by the weekend and I can't guarantee we will be able to get any more.
__________________
that should tell you
Hi there
Yes buy yourself an X1800 XT Master card and Crossfire it with your X1800 XL and you should still see a reasonable boost in performance. :)
Thanks Gibbo,
YOUR answer helped, the previous one wasn't too helpful.
No offence Lordedmond ;)
Thanks again
Yes you need the XT master card as there is no XL master card, all you lose from the XT master is 256mb, so you have an x1800 XT and an x1800 XL in Crossfire. :)
Thanks
Hussman.
All x1800 range has ceased production, so if you want to go Crossfire then as Gibbo said get your order in by the weekend or thats it. :)
can you use a master card as a single graphics card or does it have to be used in a cross fire setup (just incase you wanted to sell it on)
sorry if its a noob question
Hi there
Yes you can use one by itself, but if you need AVIVO then you will need a slave card.
no mate ive got a 7800gtx so if i do get anything it will be a x1800xt or x1900xt thanks for the offer though
