Mate needs best monitor - £250 max
3 Jul 2005
he plays quite a lot of games and uses the computer for msn quite a lot. He needs pretty good viewing angles - doesnt have to be amazing, but needs to be reasonablie- preferably widescreen, but thats only what I would choose. If theres a non widescreen which is much better, have that, and finally, it needs to be at least 19"
cheers
if you want to keep well within budget, the Acer AL1916W is very popular, as is the Samsung 913N (if you decided you wanted 4:3 aspect instead). You may also want to consider the Viewsonic VX922 which is arguably the best gaming monitor out there at the moment. Only a little over budget
