Suddenly I miss GCSE math![]()
Okay, it's been a few years, but are you sure about this? IIRC, raised indices are multiplicative, so (r^4)^(-2) = r^(4*-2) = r^(-8) = 1/(r^8).
If it was (r^4)*(r^-2) then the answer would be r^2 [as the OP had in 16 (b), where (q^5)*(q^3) = q^(5+3) = q^8]. Unless I've dropped a *BIG* one there
EDIT - These algebraic simplifications can be done on certain calculators, but I'm confident they're not allowed for your exams
If only we could do equations in posts it would make these threads so much easier!
They still give G grades
Seriously, how pathetic do you have to be to get a G at GCSE.. :/
I didn't fail, I got a G![]()
If the system hasn't changed.
Taking Higher Tier GCSE Maths; you only require 20% on Paper 1 & 2, to get a C.
40 = B, 60 = A, 80+ = A*
I usually use LaTeX syntax when sending emails about maths problems but don't on here as mosy people who ask the questions probably have never heard of it.
The infrequency with which equations come up means that instead of having to learn syntax for any equation functionality it's probably quicker just to draw it in paint if it can't be understood in text though
I understand LaTeX is the preferred method, but I really like the equation editor in Word 2007. It's most likely not as flexible or as efficient to use as LaTeX, but it's pretty intuitive and makes it very easy to write out fairly complicated expressions.
Although unecessary on these forums, it would be cool if there was a similiar system in others.
Beautifully rendered tex documents >> all else for maths papers..just looks so much nicer
There is, a lot of forums have inbuilt Latex code, so you can render some lovely equations..
..and Microsoft word, ewwwwwwwwwBeautifully rendered tex documents >> all else for maths papers..just looks so much nicer
