It's a quadratic equation, substitute Y = cos(x), solve the equation:
2Y^2 - Y - 1 = 0
Then for each of your solutions for Y, list the values of x such that cos(x) = Y. I haven't solved it, but I'd expect you to get 4 solutions.
2Y^2 - Y - 1 = 0
Using this method, you can factorise to 2(y+1/2)(y-1) so, y=1, -1/2, since y=cos(x), the solutions are when cos(x)=1 or -1/2, so
cos(x)= 0°, 360°, 120°, 240° or in rads, 0, 2π, 2/3π, 4/3π
they're not really the same solution, I'd write them both down to be on the safe side.
