Having a problem solving this, I can do basic algebra but stumped with this one. Any help appreciated.
https://ibb.co/GPfVh1R
Wouldn't know where to start and not I feel dumb!
What level of maths is this these days? A-Level?
I must admit, this took me longer than it should have because I made stupid little errors along the way.
I think I started off by subbing h= 99 -2t - s or something similarly daft, then I realised that there was 2h + 2s = 154, face palmed and started there! Far easier
Edit : In hindsight, it probably would have been better for us lot to ask you how you'd approached it @aumz and give hints/help rather than just working it all out and showing you
Year 6/7 depending on kids ability.These days no idea, IIRC we were doing something similar probably between year 9 and year 11, thought that was ~15 years ago now!
As mentioned - these type of questions are often used in 11+ exams.
111, no need for algebra. Add up right column numbers = 451. Subtract bottom row total to give ?
there are 4 answers required, aren't there?Correct. Some folks are looking at the complicated way, but the total of the numbers on the right will equal the total of the numbers on the bottom, since both totals are just the summation of all the symbols. So take the total of the numbers on the right and subtract the total of the numbers on the bottom and BOOM! Five stars and a pass with honours for spotting that one.
Truethere are 4 answers required, aren't there?
value of each of the symbols and the questionmark
