Maths/Programming Help
18 Mar 2007
Hi all,
I am struggling a bit with a concept on how to implement some timings. The example I give below isn't actually what I'm trying to achieve, but is effectively the same. Imagining this is language independent, I'd like to know how you might go about the following:
- I have a machine gun
- At first, the machine gun should start firing bullets slowly (say 1 bullet every 3 seconds)
- Gradually over the course of a given time (say 5 minutes), the machine gun should start firing faster (i.e: there should be a ramp-up in it's firing time).
- Once the 5 minutes has been reached, the machine gun should be firing at full-throttle (say 3 bullets per second).
Has anybody got any hints or suggestions on how this could be achieved?
Thanks.
Assuming this isn't the only thing happening I would set the machine gun up on a separate thread with a timer equal to the starting time between rounds. Then each time it activates reduce the timer by a set amount until it is the fastest you need.
eg timer =3000ms
timer = math.max(300,timer -15) each time it fires
PS that is a pretty slow machine gun
