mavity Control By Los Alamos National Laboratory
Permabanned
15 Sep 2006
Somewhere in York
Here is a paper by Fran De Aquino of LANL, last revised in Jan 2008 titled, mavity Control By Means of Electromagnetic Field Through Gas or Plasma at Ultra-Low Pressure
It is shown that the mavity acceleration just above a chamber filled with gas or plasma at ultra-low pressure can be strongly reduced by applying an Extra Low-Frequency (ELF) electromagnetic field across the gas or the plasma. This Gravitational Shielding Effect is related to the recent discovery of quantum correlation between gravitational mass and inertial mass.
This Gravitational Shielding Effect is unprecedented in the literature and can not be understood in the framework of General Relativity. From the technical point of view, there are several applications for this discovery.
It will change the paradigms of energy generation, transportation and telecommunications.
How much of it has been operationalised? Look at the applications it describes:
Anti mavity Propulsion for spacecraft.
Gravitational Energy Converter to Rotational Mechanical Energy by mavity Control Cells (Free energy).
Internal mavity Control inside spacecraft (Artificial mavity).
Gravitational Thrusters.
QGAs (Quantum mavity Antennas) for near instantaneous interstellar communications by Virtual Gravitational Radiation
The GCC (mavity Control Cell) antenna radiates graviphotons and gravitational waves simultaneously. Thus it is not only a gravitational antenna, but a Quantum gravitational antenna because it can also emit and detect gravitational Virtual quanta (graviphotons) which in turn can transmit information instantaneously from any distance in the universe without scattering.
QGAs for Transmission of Electric Power, solving the problem of wireless electric power transmission!
The paper concludes by saying that the process described is clearly a better way to control mavity. This is because the GCC is very easy to build, the cost is low and it works at ambient temperature.
So if it’s all that easy and cost effective to build a GCC, which is a starting point for all these applications, don’t you think this has been accomplished way back? And that much of this technology is presently being used? After all, Los Alamos isn't busy peeling potatoes!
The equations in the paper would be mind boggling to the uninitiated. You can just read between the lines to get an idea of where physics has headed!
Sources:
http://lanl.arxiv.org/abs/physics/0701091
http://lanl.arxiv.org/ftp/physics/papers/0701/0701091.pdf
http://users.elo.com.br/~deaquino/
http://www.abovetopsecret.com/forum/thread337165/pg1
Makes an interesting read.
No need to fight that pesky mavity to get to orbit? Think of the benefits to things like spacecraft or even aircraft etc. It's a a truely incredible discovery if it's as good as they think. It could revolutionise... everything.
In my lifetime.... I hope so. I really wish for this to come true... I want to see the world reformed by this, not sure how long it would take though.
It was my understanding that mavity is a force - what is the 'gravitational energy' that they keep talking about?
Consider a book, placed on top of a table. When the book is raised from the floor to the table, the gravitational force does negative work. If the book is returned back to the floor, the exact same (but positive) work will be done by the gravitational force. Thus, if the book is knocked off the table, this work (called potential energy) goes to accelerate the book (and is converted into kinetic energy). When the book hits the floor this kinetic energy is converted into heat and sound by the impact.
because none had ever thought of putting an Extra Low-Frequency (ELF) electromagnetic field across a very low pressure plasma before, because there was no theoretical reason too?
You do realise that those arnt my words right?
For people who need filling in, quite a good documentary to watch here from Horizon:
http://www.spikedhumor.com/articles/143756/BBC-Horizon-What-on-Earth-is-Wrong-with-mavity-1-2.html
http://www.spikedhumor.com/articles/143759/BBC-Horizon-What-on-Earth-is-Wrong-with-mavity-2-2.html
they weren't in quotation marks, and I was doubtful that meaningful source would diverge off into conspiracy theories like that.
I'm also curious to how the person changed "information transfer" to electrical energy, as that would be quite an odd step.
Get back to school/college and soak up what they teach you like a big sponge.......cos its all 100% true I tells ya. The theory of evoluition man was a fishy on a little dishy and sprouted legs and ate the little fishy on the little dishy with some chips.
:confused:
:confused: Most random post ever?
Hmm not much a defending army can do if it can't stay on the ground due to anti-grav.. ok that's a bit far fetched but it would have crossed someone's mind at some point..
Well if that means no more cut cables and proper broadband then I'll be happy!
The term space craft - note the propulsion is magnetic, which isn't quite as simple in deep space when you're not within a planet's magnetic field.
