Max Core 2 Duo Overclocks at Default Voltage Info
27 Jan 2003
Chesterfield, UK
Hi there,
Thought it would be interesting to see how the C2D are performing at default voltage. One of the things that always impressed me about the Opteron 939's was the ability for some batches to perform 3G's at default voltage.
I currently have a 6600 that will do a tad under 3.6G at default voltage which is 1.35 volts.
Would be nice to get some info on what batches are performing the best.
Orthos stable for 1 hour is a good indication of stability and works for me so if you could perform this I would appreciate it.
See my screen shot for required info.
I'll will compile a list depending on the response.
Remember *** Default Volts Only *** Just set Vcore to Auto
Any VCore measurements should be done under load otherwise the power management will reduce it.
I will start the ball rolling
X6800
6700 - Default VCore 1.350
6600 - Default VCore 1.350
The Asgard - L629A531 (Week 29), P5W64, Watercooled, VCore 1.33, Overlock 3.585 ** Orthos Verified **
VoG - L629A810 (Week 29), BadAxe 306, Watercooled, VCore 1.30, Overclock 3.3G ** Orthos Verified **
Its Me - L629A959 (Week 29), P5B Vanila, Intel HS, Default VCore, Overclock 3.294
w3bbo - ????????, P5W DH, Watercooled, Default VCore, Overclock 3.25G
Concord Rules - ????????, P5B Delux, Intel HS, Default VCore, Overclock 3.18
Xez - L626A481 (Week 26), P5W DH, Scythe Ninja, VCore 1.296, Overclock 3.04
6400 - Default VCore 1.325
Biglunn - L629A725 (week 29), P5B Delux, Arctic Cooling Freezer 7 Pro, VCore 1.32, Overclock 3.2
Methanoid - L630 (Week 30), DS3, Arctic Freezer 7, VCore Default, Overclock 3.2
6300 - Default VCore 1.325
Servo - ????????, DS3, ?????, Default VCore, Overclock 3.222
BigStan - ???????, DS3, Arctic Cooling Freezer 7 Pro, VCore 1.30, Overclock 3.15
WGA96 - ???????, DS4, AC Freezer Pro 7, VCore 1.297, Overclock 2.84
hardc0re_tid - ????????, P5B, Artcic Freezer 7 Pro, VCore 1.325, Overclock 2.8
Dude crop your screenshot... it's way too big and even stretches the screen on my 1690*1050 rez. You can cut out almost the entire right side of the pic there.:D
I'm going to test this today and will add to this post with the results... i'm thinking 3.2-3.3ghz or around there though. Not fantastic. :o
Done.
Sweet m8. Nothing wrong with 3.2 to 3.3 at default.
iirc 3.25ghz was my max stable on default. Been a long time since I was at such a low vcore though :D
If you could please supply
CPU Batch Number
Motherboard
Cooling
Actual VCore in use. Everest is good for this.
Overclock
1 Hour Stability test with Orthos ( if possible )
Appreciated
I have played with over 20 6600 now with my latest being Week 31. So far the best clockers at default are Week 29's.
Xez said:
E6600 Batch L626A481
Asus P5W DH
Scythe Ninja
1.296v
3.04ghz
Is that at default in the bios m8 ? Could you look at it under load ?
E6300 - No batch code?, bought as OEM, B2 stepping
Gigabyte GA-965P DS4
AC Freezer Pro 7
1.297V (BIOS says 1.35V)
2.84GHz
Fully stable running 2 threads F@H 24/7
My machine defaulted to 1.35V but your post above says 1.325 is the stock voltage - are Gigabyte giving them a bit extra juice on purpose?
AC Freezer Pro 7
2.84GHz
Try Looking at the Load VCore voltage. It should go up. C2D drop the voltage at Idle
Nope mine on idle is 1.3 to 1.32v and load of 1.296v set to default voltage in bios
That is under load. The first thing I do is turn off C1E/EIST/Speedstep and then stick on Folding@Home. None of my machines ever run less than 100% CPU utilization.
Or more likely the voltage measuring chip is a piece of junk. Voltages are actually only relevant between measurements on the same machine, surely? I've never seen one of these programs report the same voltage that the BIOS is actually set to. Has anyone?
^^ Correct.
I haven't seen a mobo report the same as others exactly.
1.25V in BIOS = 1.208V under load, 1.212V idle.
1.5675V in BIOS = 1.504 under load, 1.524V idle.
CR.
E6300
CPU Batch Number - Forgot to look :o
Motherboard - Gigabyte GA_965P_DS3
Cooling - Arctic Cooling Freezer 7 Pro
Actual VCore in use - 1.30 (bios says 1.325)
Overclock - 3.15 (450x7)
Orthos stable and running two cores of F@H 24/7 for the last 3 weeks.
Stan :)
don't have all the other bits and bobs off the top of my head, but my 6400 does 3.2ghz on stock volts but i need to slacken mem timings, i've had it in windows at 3.4ghz on stock volts also :D.
*note as you can see that's on air and on a p5b deluxe!
