Hi, been a while since i been to these forum since the system was whiped
Anyway I've been on 1mb with AOL for about a year now and somhow managed to upgrade to platinum tho the BT checker say's 1mb is the max.I should have maxDSL in next 2-3 days which is where the problem is.I have a BT 105 modem and a NetGear DG834G v2 router
Line stats from BT 105 http://img.photobucket.com/albums/v468/shebalator/BTstats.jpg
Line stats from Netgear http://img.photobucket.com/albums/v468/shebalator/Netgearstats.jpg
The Netgear gives a lot better SNR but after say...8hrs uptime for example it drops to 6dB and stays at that where as the BT 105 stays at 15-16 SNR.
So what should i use
Also whats the best modem to use for a long line to get best maxdsl speed?
Thx in Advance
PS
BT Checker says 1Mb but 1.5Mb or greater for Max DSL
Anyway I've been on 1mb with AOL for about a year now and somhow managed to upgrade to platinum tho the BT checker say's 1mb is the max.I should have maxDSL in next 2-3 days which is where the problem is.I have a BT 105 modem and a NetGear DG834G v2 routerLine stats from BT 105 http://img.photobucket.com/albums/v468/shebalator/BTstats.jpg
Thx in Advance
PS
