- 26 Aug 2019
Hoping to play dota2 in leagues at 4K so when the ultimates drop and my frame rates half I will have decent frame rates I will be planing to do this with Spotify and discord running and streaming with delay
Planing on buying in the next 4-6 weeks
Budget 5k or less but flexible if needs to be.
My present system was objectively a failure not reaching my desired frame rates at 1440p
With a 3080
It’s likely overkill dota dosent really use more than 6 cores far as I’m aware
CPU: AMD Ryzen 9 9950X3D 4.3 GHz 16-Core Processor
CPU Cooler: Corsair iCUE LINK TITAN 420 RX RGB 94.7 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX X870E-E GAMING WIFI ATX AM5 Motherboard
Memory: G.Skill Ripjaws M5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL28 Memory
Storage: Crucial T705 4 TB M.2-2280 PCIe 5.0 X4 NVME Solid State Drive
Video Card: MSI VANGUARD SOC GeForce RTX 5090 32 GB Video Card
Case: HAVN HS420 ATX Mid Tower Case
Power Supply: Corsair HX1500i (2025) 1500 W 80+ Platinum Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 11 Home Retail - USB 64-bit
Case Fan: Corsair iCUE LINK LX140 RGB 84.7 CFM 140 mm Fans 2-Pack
Case Fan: Corsair iCUE LINK LX140-R RGB 90 CFM 140 mm Fans 2-Pack
Case Fan: Corsair iCUE LINK LX140-R RGB 90 CFM 140mm fans 2-pack
With a 3080
