Max GPU temp?
21 Feb 2006
Home
My XFX 4890XT keeps hitting 100+'c. Is this normal for ATI?
*Edit* PC keeps locking up and getting stupid lines on my display.
Think RMA time.
Actually, just gave my card a blow and more dust came out. Going to give it another blast with air tomorrow and give it another try.
Personally I'd give it another clean just to be sure, you did say more dust came out which is telling you it is a bit clogged. My temps dropped by 25 degrees after thoroughly cleaning mine. After a few months the dust will usually build up to where the idle temps rise. That's when you need to sort it out.
Obviously if this doesn't help them it's RMA time. Good luck. :)
