- 7 Aug 2004
As title, my old 670gtx nvidia could run 4 monitors, my r290x can run 3.
Can 980ti run 4 ? Is for a work station setup
i updated my post, you can ifnore the integrated graphics then, but your second card should be able to run the 4th monitor or even 2 of them.
Ah i see, i guess the only option is the MST hub for the two displayport cards, they sell them on overclockers.
https://www.overclockers.co.uk/showproduct.php?prodid=CB-017-SR may just need a mini to large adapter too, but i dont know if it comes with one in the box.
handy to have anyway, even if you change cards in future since you can use it to have 6 monitors.
