MAx overclock for q6600 with...
PC8500 will stick to a Q6600 upto and probably over 5ghz.
So you'll be more than fine with it.
Damn... only 5Ghz? :D
Does this mean then that i wont have to do anything to my RAM when i overclock my Q6600?
I also plan on overclocking my G8 seens as im told its easy with software :)
There's a bit of debate about that. Some people say 1:1 is best, some say it's fine to run on a divider.
Personally I'm running my PC8500 on the 4:5 divider as it gives me higher bandwidth benchmark scores.
How do the ratios work? Im curious about this stuff to.
Currently i was going to buy 1066Mhz, could i set the rations so that all of the 1066 is being used or almost all of it?
I plan on clocking my q6600 to 3Ghz, although its going to be GO so i might put it up to 3.2 hopfuly!
Im confused as to how all this ram works. And if you dont need 1066, why do people overclock it to 1200?
Because they can.
And yip you can set a ratio so that your PC8500 is running close to 1066mhz. Most of the newer boards have a x4/1:2 multiplier/divider that lets you run your memory at 1066mhz with your FSB at only 266mhz.
Ok then thanks.
So how do you set the divider? is it just an option in the bios where you type in a ratio?
If i had my Q6600 at 3 GHZ, possibly 3.2 GHZ.
Then how would i work out the ratio? That way i can work out the ratio if i do have a slightly differnt clock.
1066 DDR2 is running at 533 because its double right? And my processor at 320. Would i have to set the ratio at like 4:5?
