Max Payne 3 Launcher
14 Aug 2007
York, UK
Having trouble playing Max Payne 3, its saying when i launch the exe its saying "Please start the game using the launcher" cant find a solution at all online, only solutions for cracks. It is a retail copy if the game, no steam
Thanks you kindly
Make sure your firewall allows it through I bought the game cheaply @ retail last week it came with a big warning about disabling all AV & Firewall software BEFORE installing perhaps something blocked it on your PC.
Have you tried taking out then putting the DVD in the drive again and waiting for the autorun - it may need to run the 'launcher' from the DVD, which then runs the main program from hard drive.
Not got it to check I'm afraid, so may not work.
can't remember but sure u have to run the Rockstar software then launch Max Payne 3 if u havn't got that install go to there website and download it and install it the game wont work without it
Heres the Link
Got it working, happen to look at compatibility mode and it was set to windows 98. Changed it to windows 7 and bingo it worked. Weird if u ask me but thanks all the same guys
