max safe temps for the 6970 ?
Hehe, just accidentally learned that the gpu throttles when it reaches 102 degrees Celsius
Didn't crash so "our" 90's should be fine...
From guru. Yea with a stock fan profile that is pretty normal, nothing to really worry about.
Very hard to get a spec on max temp with GPU's for some reason.
I haven't hit 90 on either of my cards, what are you using to get this reading?
Try running the latest GPU-Z in the background and see if it gives the same results.
If it does then try doing it with the side of the case off.
Just getting about a couple of minutes of playing should get the temp's in that region hopefully.
Latest GPU-Z here
just tried running gpu-z and that says 91c with a fan speed of 48% , reminds me of the old nvidia fx5800 when the fan hits 48% (loud hairdryer lol)
90+ seems normal on some games, i did another post where i tested about 4-5 games played for an hour on each and laod temps were anywhere from 65c-95c with DOW 2 being the most intensive. Like i said in another post be aware some people are posting their temps with 50+ fan speed which IMO is not acceptable for normal gameing even with a headset, And the other half posting these super low cooler then cool temps are just full of it ;)
Mine card runs around 83c while playing AVP, even BC2 gives me temps around 80c. I was kinda shocked when i saw how AVP stresses mine GPU. I would say that your temps might be ok, as it depends what kinda of case you're using.
A good case with good airflow can make difference, i like big cases with lots of fans like the antec 1200 and coolermaster haf 932 but there are cheaper options
Im working all weekend but monday i will give avp a blast and see what temps i get, there seems to be mixed fellings about the 69** temps some say they run hot and others say they are ok, if mine was running hot i think i might be tempted to remove the heatsink and renew the tim, easier said than done though
Was just playing AVP for a while and was at 81c at 50% fan. So yeah I'd imagine on auto fan 38% it would go to early 90s.
I've just decided to keep my fan at 35% when idle and 45% when gaming and it keeps it cool enough.
Just tryed mine for you 1900x1200 res every thing max setting and i mean mac no x4 rubbish and i got 83c at 38% auto fan speed so again about right it pretty chilly up here in the north tonight
my case helps massivly i dont have a single cable restricting airflow and the 3 fans blow air through the short body of the case
those were my 5870 now 6970 ofc
