Okay, suppose I'm using liquid nitrogen or something and heat isn't an issue. Is there an upper limit on how many volts I can push through this chip? Like if I put 2 volts through it, would I knacker it even if it didn't overheat?
on a superpi suicide run. These chips are awesome and can take an electronic beating unlike their newer 45nm brethren!
I got to nearly 2v on a e2180 and my water held the temps fine but didn't help the clock. Wouldn't post at 3.8Ghz.
Okay that failed. The chip will go no higher on 1.8v it seems. Tried 3.42, it POSTed but failed to load Windows. Ah well.
I cant get mine stable over 3.2GHZ regardless of whether i go above 1.55v or not. Increments on my gigabyte board after 1.6 are 1.8 and 2.0 with nothing inbetween and at 1.8 it fails after post and at 2.0 it wont even post. Can boot into windows at 3.4GHZ 1.6v (1.575v in CPUz) but it fails under orthos.
Shouldn't need that much voltage on the CPU for that clock. What ram divider are you using? Have you tried increasing the volts on your NB slightly?
