- 11 Dec 2005
- Brighton
maximum memory speed with AsRock 939 dual SATA2?
Hi folks,
I am trying to get the maximun memory speed (OCZ 3500EB) and maximun overclock of my opteron 146 in my mobo with 1.5 bios and I find the following problem:
with a 133 divider I get HTT 274x10 at 1.45v (overvolts to 1.475v) and memory about 200 Mhz (2.5-2-2-9)
with a 166 divider I get HTT 265x10 at 1.425v and memory at 220 Mhz (3-3-2-9 and 1T) with high setting memory volts.
I bought an OCZ booster aiming to get the max of my memory at 10x274 using the 166 divider (so memory at 228mhz) but I fail prime95 and superpi
My memory is memtest stable at 232mhz (2.5-2-2-9 with 2.95v) and my processor is also stable at 2750 Mhz so the problem is somewhere else.
So now I am stuck at HTT 266x10 at 1.425v with memory at 221 (2.5-2-2-9 1T); not a big increase to justify buying the booster. Any single increase in HTT end up failing prime95 and superpi even increasing cpu volts to 1.45. I can increase HTT beyond 266 only if I use 133 divider.
is anybody running this mobo with high memory speed & HTT and 1T??? if so what bios? volts on the cpu?
I read in one post that the mobo has problems to run 1T with high memory speeds specially without a memory divider. can anybody confirm this????
Hi folks,
