"Maxium 133GB fomatted capacity per disk" <-What does this mean?
only thing i can think of is that you can set the jumper so that it only shows as 133GB to keep backwards compatible with older hardware
Chrisss said:
If I wanted though could I have just one partition that used all the space on the disk?
Nope because some old(ancient) hardware would refuse to see the harddrive if it was too big
Either the motherboard is old and cant support larger hard drives or your not using win xp with service pack 1 as that service pack fixes for larger hdd sizes.
