Caporegime
- 17 Oct 2006
Hi
Sorry had a read through the sticky but im still scratching my head on the sata thing (first time ever using it). Building up a new system E6600 on a SD3 Gigabyte mobo and am about to install the Maxtor 200gb Sata 3.0gb HDD when i noticed a small jumper on back with two settings:
SATA 1.50gb/s Mode Setting and the other J4 (Partial) (thats where jumper pin is on straight from box)
So is this jumper setting correct or should it be on the Sata 1.5gb pins? Am only using the one harddrive. Thanks for the help and your time.
