- 21 Feb 2003
- Southampton
Have just built a new system, and it is obvious to me now, that there are problems with Maxtor drives and Nvidia Nforce boards.
The m/b is a Asus A8N32 Sli Deluxe & the two drives are Diamondmax 10 300 gb satas.
I can create a raid 0 array, and load the drivers when hitting F6 on the windows initial install, but when it comes to the part when you hit enter (it should then go on list the drives, and where you want to install etc), it comes up with there are no drives on the system.
Contacted Maxtor, and they sent me the relevant firmware - and I copied it to a floppy, and then booted to a cmd prompt. When I type Dload, it says there are no Maxtor products recognisble!
The above was attempted on the Silicon image controller - (set to SATA2) on the Asus (and it was enabled in the bios, and shows up on the POST screen)
I've been trying to get this system running for hours now, and have almost given up. Anyone have any ideas on how I may be able to flash these drives, and get them working.
Many thanks in advance.
