** MAYHEMS BLITZ CLEANING KITS AVAILABLE NOW + COMPETITION WINNERS ANNOUNCED **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
It gives me great pleasure to finally announce availability of the new Blitz cleaning kits from Mayhems.
This is perhaps the most comprehensive system cleaning solution ever offered to the watercooling community. Both kits contain everything you need to perform a full system clean and ensure that PH levels are correct before putting new fluid in the system.
The Blitz kit is designed to clean radiators and blocks and keep your watercooling system running in peak condition for longer.
The Pro Kit comes with everything you need including a PH meter so that you can check your PH levels regularly to ensure best running of your system and the Basic kit ships with the same stuff except for the PH meter.
This is obviously not for everyone and really aimed at hardcore watercooling enthusiasts who want absolute control over the coolant in their system.
Mayhems Blitz Pro Cleaning System @ £24.95 inc VAT
Mayhems Blitz Pro Cleaning System is the most comprehensive cleaning kit ever released for liquid cooling computers. It has been developed to clean you radiator’s better than new and leave your system in perfect condition. It even comes with a electronic pH test meter so you can check your levels and keep up with regular maintenance on your system
Even though this is a cleaning solution it is not a long term effective inhibitor. Never leave it in your system longer than 24 hours.
This cleaning system is not safe to use around children and animals. Part 1 and Part 2 of the system uses highly effective cleaning acids down to PH 2 and you must take appropriate measures when using such products. You can dispose of the fluids down the drain once they have been diluted.
Contents
· 100ml Mayhems Blitz Part 1 100ml (will dilute to 2 Ltrs of fluid)
· 100ml Mayhems Blitz Part 2 100ml (will dilute to 4 Ltrs of fluid)
· Rubber Gloves 4 sets
· Safety Goggles
· PH test Meter
· PH Buffer solution
· Instructions
· Warning Sheet
Part 1 Mayhems Blitz Pro Cleaning
DO NOT USE ON ALUMINIUM RADIATORS
For internal use on Capper / Brass radiators only.
Do not use on plated products.
Do not spill on paint work and if you do so, rinse off immediately.
· Maximum effectiveness
· Rapid neutralisation of surface rust, contamination and oxidation
· Rigorous removal of mineral scale deposits
· Excellent suspension of particulates
· Low foaming
· Hard water tolerant
· Can be disposed of down grey-water (waste / outside) drain
· With "Care" this is easy to handle and straight forward to use
· May Improve heat transfer rate
Usage of Part 1 of the Mayhems Blitz Pro Cleaning System
1. Put on the Gloves provided in the kit.
2. Mix Part one with deionised water / distilled water (either will do) to a ratio of 50ml of part 1 to 950ml of water.
3. Add to the radiator and clean up any spills immediately.
4. Vent the system of any trapped air and cap the radiator.
5. Recirculate for a maximum of two hours. (shake every 10 min)
6. After two hours empty down the waste drain. DO NOT LEAVE LONGER THAN TWO HOURS
7. Refill with deionised water / distilled water (either will do) and rise out.
8. Repeat this 2 times.
9. Refit to loop and move to Part Two of the cleaning system.
Part 2 Mayhems Blitz Pro Cleaning System
· pH neutral (Ph7 -0.5 / +0.5)
· Effective neutralisation of contaminants.
· Good removal of slime, silt & detritus
Usage of Part 2 Mayhems Blitz Pro Cleaning System
1. Drain existing system contents.
2. Mix Part two with deionised water / distilled water (either will do) to a ratio of 25ml of Mayhems Blitz part 2 to 975ml of water.
3. Mayhems Blitz Part 2 will create a lot of foam. Please add to system slowly, do not over fill.
4. Vent the system of any trapped air. Do this by tilting the pc to release any tapped air from the radiator.
5. Check for leaks. Using just the pump, recirculate the fluids for 24 hours continuously. Regularly check any installed filters and clean as necessary.
6. Refill with deionised water / distilled water (either will do).
7. Run for 30 minutes
8. Empty out and refill with deionised water / distilled water (either will do)
9. Run for 30 minutes
10. Empty out and fill with your favourite coolant.
WARNING
Only £24.95 inc VAT.
ORDER NOW
Mayhems Blitz Basic Cleaning System @ £19.99 inc VAT
"Mayhems Blitz Basic Cleaning System" is a single part highly effective cleaning system for liquid cooling loops. "Mayhems Blitz Basic Cleaning System" is a whole system flush that will not only clean the system it can improve the overall performance of your system.
This cleaning system is not safe to use around children and animals. You can dispose of the fluids down the drain once they have been diluted.
Documents
Warning PDF
Cleaning Docs
Contents
- 100ml Mayhems Blitz Part 2 (100ml will make up to 4 Ltrs of cleaning fluid)
- 60ml Messuring Cup (Graduated every 5ml up to 30ml then every 10ml up to 60ml)
- Rubber Gloves 2 sets (4 single gloves)
- Safety Goggles (you can still ware your normal glasses at the same time)
- Set of PH test Strips
- Instructions
- Warning Sheet
- pH neutral (Ph7 -0.5 / +0.5)
- Effective neutralisation of contaminants.
- Good removal of slime, silt & detritus
- Excellent suspension of particulates
- Hard water tolerant
- Can be disposed of down grey-water (waste / outside) drain
- May Improve heat transfer rate
WARNING
Only £19.99 inc VAT.
ORDER NOW
Might be worth fitting a fill and drain line (or running the loop outside your case) when completing the part 2 cleaning cycle
'Mentos' foam fountain on your graphics cards anyone
5l bottle of deionised water also required as a minimum (that three full fills and drains).
Also are you pumping foam round - or only pump when all foam is gone?
Part 1 is straight forward enough (but more dangerous due to the strong acid) Warning sheet inc
Part 2 need Much more detailed instructions (but knowing Mayhems that's included)
Part 1 should beat a white distilled vinegar bath.
Part 2... looks like the USP
Awaiting youtube clip of someone trying out point 3 'Mayhems Blitz Part 2 will create a lot of foam' for comic effect
Edit: I think it's a great product, but hardcore watercooling enthusiasts only!
The horror story threads just waiting to happen may be a PR nightmare
And the last thing I'd want to see is Mayhems getting a bad name
My micro loop is out of the case atm so will happily test a sample and give a review if I get picked - hopeing to be pleasently surprised.
Much more left to do on my system yet but I gave to say that the Mayhems Pastel Red is awesome stuff!
It needs draining to add a proper drain port and temperature sensors so it will need flushing through again
How long does the Competition go on for, as i dont have a full case shot and should receive my repaired camera in the next few days.
Geared up with so much EK!
Two EK radiators, two EK pumps, EK Compression fittings, EK adapters, five EK blocks, EK tube reservoir and EK hd fittings. It is no secret that I have perhaps a bit too much love for EK :D.
Mayhems UV red.
Currently running Mayhems X1 Clear with Mayhems Red Dye
Previously, Mayhems Red Pastel
Wanting to switch to White Pastel soon so the kit would come in handy!
Could one of you guys link me to an example of some of those cables (on OcUK) you are using as the cabling in your systems looks way better than mine?
I worked it out .;)
Using this myself ;- Mayhems X1 Clear Premixed Watercooling Fluid 1L
Every thing else is XSPC .
How do you post a pic ? so i can enter ....Help please ?
Use photobucket or similar to host your picture and then link it to the website. Simples :)
I use mayhems silver kill coils but its not gonna show up in the picture so I dont think that would count .
