Hi Guys
Launching today we have two very cool products from Mayhems
First up is their new range of traditional tubing. This stuff is a great price point as well as being really clear and having no nasty rubbish in them like some of the other brands.
Secondly is their new range of Borosilicate Glass tubing. Yes, thats correct. GLASS. It looks insane, is clear as... Glass and has no nasty rubbish in it. Perhaps the most hard wearing and unique thing you can put in your system.
You need to cut this stuff with glasses/goggles and gloves [glass dust is VERY bad for you] you need a diamond cutting blade for your modding tool or power tools to be able to cut this correctly.
Here is a video on how to do it:
Mayhems Ultra Clear Watercooling Tubing (12 - 34) 1319mm @ £1.69 inc VAT
The Mayhems ‘Ultra Clear’ product sets a new standard in transparency with our new flexible tubing and is simply epochs ahead of all the new EU standards that will soon be in effect. Our ‘Ultra-Clear’ tubing utilises new ’Polymer Additives’ that do not leach plasticizers into the system, which can lead to fouling and blockages.
Mayhems ‘ultra-Clear’ does not employ the use of Phthalate materials, which again lends credence towards a higher quality product than other types of tubing. Mayhems has liaised closely with a leading tube manufacturer within the United Kingdom in order to convey to you this high-grade product so one now longer needs to ‘take a chance’ with sub-par tubing.
Sold in 1m Lengths, The quantity you select is the length in meters that you will be suppplied with.
Only £1.69 inc VAT.
ORDER NOW
Mayhems Ultra Clear Watercooling Tubing (38 - 58) 1016mm @ £1.69 inc VAT
Only £1.69 inc VAT.
ORDER NOW
Mayhems Ultra Clear Watercooling Tubing (38 - 12) 1013mm @ £1.39 inc VAT
Only £1.39 inc VAT.
ORDER NOW
Mayhems Hardened Glass Watercooling Tubing Straight 16mm (OD) x 500mm @ £7.99 inc VAT
Mayhems bespoke laboratory grade, hand blown and hardened glass tubing are made in the UK to the highest possible standards.
Developed from the ‘ground up’, Mayhems Laboratories have taken the concept of ‘Glass Like’ to the extreme and utilised local knowledge within the UK to produce hardened tubing for liquid-cooled PC’s. The size of the tubing conforms to standard sizes that are common within the industry today.
Mayhems tubing is fully compatible with other popular fittings from Primochill, Bitspower, EKWB, Thermaltake and other popular watercooling fittings. Mayhems Borosilicate Glass Tube tubing has been stress tested beyond ‘normal’ temperatures (100c+) and tested with all Mayhems coolants
Warning
Use appropriate safety measures when working with glass, this include safety glasses / goggle and gloves. Dispose of glass off cuts and glass dust safely. These products do not break into small fragments they shatter into shards.
Only £7.99 inc VAT.
ORDER NOW
Mayhems Hardened Glass Watercooling Tubing Straight 12mm (OD) x 500mm @ £6.95 inc VAT
Warning
Only £6.95 inc VAT.
ORDER NOW
Mayhems Hardened Glass Watercooling Tubing Straight 13mm (OD) x 500mm @ £6.95 inc VAT
Warning
Only £6.95 inc VAT.
ORDER NOW
Only £1.69 inc VAT.
ORDER NOW
Only £1.69 inc VAT.
ORDER NOW
Only £1.39 inc VAT.
ORDER NOW
Warning
Only £7.99 inc VAT.
ORDER NOW
Warning
Only £6.95 inc VAT.
ORDER NOW
Warning
Only £6.95 inc VAT.
ORDER NOW
