I'd recommend you redo the video with someone using the correct safety gear unless you want suing by every tom dick and harry who can't scribe a glass tube correctly. It's like a solicitors wet dream come true, esp when it comes from the manufacturer.
It even makes white look pretty spesh though, jeez I just got all my fittings for soft tubing and this is really starting to sway me......hard tubing and divorce or soft tubing and married bliss?????
So I bought the clear tubing.
It has a bit blue hue but once u put it in the system and put coloured coolant in, u will not see the difference vs primochill.
They are worth the price!
Tried some of the 16/10 clear tubing. Seems to kink a lot easier than the Primochill tubing. Amazing for the price though, hopefully they won't go cloudy after a few months like the Primochill.
