you need a bigger hammerIts hammer Time ....
"snip"
You cut them with a cheap diamond cutter on a dremmel and then sound down with wet and dry (use it wet). Use a Paper mask and protective glasses when working on it. Its not hard top work with. Then use any hard line fitting for 12,13 or 16mm.
This is a much easier way of doing it now -
