Boot or bonnet latch sensor - had a similar sounding issue with my car.
Yeah, hopefully. The big hint for me is the fact the boot has opened itself about three or four times during this period.
I know mine could do with a new battery, the current battery is the smallest capacity recommended for the vehicle.My father in law had a 2009 Mazda 6 and that started having the alarm go off at random times, usually in the night, with in a week or two the car battery died. Pretty sure it did this twice. Anyway, he replaced the car battery and after that it was fine.
Hello. I've had the same issue on my
2010 Mazda 6. The hot weather has definitely been a cause. It's been to the garage, no fault codes, new battery installed. on the same day I discovered something new to try, I've trawled the internet and found it could be the heat pressurised in the car mixing with cooler air thats Triggering the alarm.Shut all vents, point the direction of vents to the footwell and set the heat high. You can switch the heater off. For the first time in a week forgot to shut all vents and it went off yesterday morning at 8.30am. Someone has mentioned it could also be a separate battery for the alarm? It's very embarrassing if nothing else!
I also gave the tailgate hinges and lock a spray with WD-40 to eliminate any friction when closing the boot.Hi guys, thank you for the additional responses. It really has been helpful. I wanted to give an update.
It actually has been behaving itself for the past few days and I got a garage to look at it for free this morning. They've hooked it up to the diagnostic equipment and it is coming up with the same trigger for the alarm each time, which is the boot locking mechanism. They said a new boot lock mechanism was coming up at £280 + VAT! So, I took the car away again and they're fine with me sourcing one myself. I've seen a few already which i think appear to be the same thing from my age of mazda (2010) for £20-40, and the garage will happily fit it. They said they'd like me to get the microchip too, from the button on the car where you press it to open the boot.
I believe it is against forum rules to link to a well known auction site on here, but I'm enquiring at the moment!
And finally, it really has been hot the past few days and I would have expected the alarm to have gone off multiple times... but having followed some advice on this thread and slamming the boot shut quite hard.... I'm wondering if that alone is fixing my issue, so I perhaps could do to wait briefly to see if it even does it again.
My wife still can't understand why I open the side door every time I close (slam) the boot.
Gone out to mine just now - boot closes as follows:Oh, I forgot to mention one thing above by the way. Could anybody with an MK2 Mazda 6 (2010 in my case), please do me an enormous favour if they remember at some point. Could somebody please close their boot as they normally would, and as the boot slams shut, do you see the boot itself clearly shift upwards by perhaps a few millimetres or so a fraction of a second later? The garage thought the fact that mine does this was further confirmation of the boot locking mechanism issue. They seemed to think when you slam it shut, there should be no movement upwards at all.
Slam shut - motor operates and boot goes down (below flush) - slight pause - motor operates and boot raises a few mm (flush).
Another common fault is the rubber boot button perishing and water getting in. This can cause the button to go a bit haywire. I’d check that out first before replacing the locking mechanism.
I use the word "boot" to mean both tailgate and trunk - is your vehicle a saloon (trunk) or hatchback (tailgate) ?It really does seem more prone when it is very hot/sunny. It seems to just not do it when the weather is cold/rainy.
Also, update... just slamming the boot doesn't work! The alarm just went off right now![]()
There is a "Liftgate Latch Position Switch" positioned somewhere near/on the boot lock.Mine is the hatchback version.
