Hi guys,
Well, it looks like my white 2006 MacBook is beginning to give up the ghost. It has been a bit tatty for a long while and now the screen is failing. I don't really have many complaints because it has been used and abused pretty much daily for 3 years straight. There is still life left in it - I think I'm going to use it for testing purposes.
Anyway, for general usage, I'm considering the 13" MacBook Pro as a replacement and I have a few questions.
That's about it really, I'm going to do some more reading this afternoon but you know what it's like - if you take your finger off the pulse for a couple of months you pretty much know nothing.
Any input from MBP owners who have lived with it for a while would be much appreciated.
Cheers.
- Firstly, the old classic, would you wait or buy now? I'm not desperate, but I take it there is not a significant update on the horizon? I was thinking of waiting till Snow Leopard, but from what I've read the upgrade cost is minimal.
- One thing that could be improved with my current MacBook is durability. Am I correct in thinking that these new aluminium MacBooks with their glass screens are much more sturdy? Are there any common defects I should know about?
- Another thing that annoyed me about the MacBook was the fans - a little bit of CPU activity and the fans ramped up after a couple of minutes. I suppose it isn't a dealbreaker, but is this situation improved much?
- Is the 9400M compatible with OpenCL?
Cheers.
