Mechanical Keyboard...
17 Mar 2005
Oxfordshire
Hello,
I need a little advice from people who have been in a similar situation.
Basically I started off with the 6GV2 SteelSeries black switches keyboard, while I loved the build quality and the general feel, I found that I suffered from fatigue on my gaming sessions after a few hours.
I then switched to a Filco Majestouch Ninja 2 with brown switches, I solved the problem with fatigue with these but lacked the smoothness of the black switches on my previous keyboard.
My dilemma is, that while I was ok with the brown switch keyboard, I melted it and it is now unusable and I am in the market for a replacement.
From what I have read the best for my requirements are red switches, giving me a similar feel to the black switches but without the force needed to activate the key. I've seen a few on OcUK but I am still quite undecided at the moment.
Is there anyone out there that has converted to red switches and can recommend a keyboard that:
Excellent build quality and great looks (although really not that important)
Any feedback is welcome :)
Many thanks.
Yup, sounds like red switches are the ones for you.
Personally I think the Qpad would be the better choice... I prefer the look of it over the Corsair. However, both are very good red switch keyboards.
