Media help.
ajm
ajm
13 Apr 2004
Not quite sure where this should be posted but please move if needed.
I am looking for something that can be plugged into the tv and can play movies and music etc from possibly a hdd,but also would like it to have 5.1 connections like below...The smaller the better as i don't want a pc or anything that big.
That looks a real expensive way to go by the time all components are added to it.Looking for something like the BNI media box but with the 5.1 connections as shown in my post.
Budget is probably around the £100 mark but could be higher if the right product is available.
Thanks for the link but i already have a divx dvd recorder but were looking for something smaller (Portable) as an extra.
Unfortunately only available from compeditors. Don't know how the rules apply in this regard if OCUK don't stock a particular item. Due to its size its also only got digital coaxial output.
"' ' is a compact & excellent quality portable multimedia player. It gives you freedom to playback all your favorite video and audio files anywhere you go - at home, hotel room, in the office, client office, even in the car! It supports various video formats such as AVI, DAT, MPG, VOB, ISO, IFO etc, and surround sound with 5.1ch digital coaxial audio format. A built-in FM Transmitter also makes you enjoy digital movies and music in the car by tuning radio frequency. Besides it can be used as a multimedia player, MP3 player or photo slider on HDTV. ' ' also works as a USB 2.0 storage device to backup all your valuable data."
@monkeysmith
I know i am struggling. :eek:
@wizardmaxx
As long as you don't post a link you could say the make & model number.
I am also looking into changing my amp so that it can take the 5.1ch digital coaxial audio format and then this search would be easier,not having any luck with that so far either.
