Media PC Spec
6 Sep 2005
Hi guys,
any comments or suggestions on the below spec for my new media PC?
AMD Athlon 64 3000+ Venice 90nm (Socket 939) - Retail (ADA3000BPBOX) (CP-117-AM)
£74.95 £74.95
Gigabyte K8N51GMF-9 nForce 6100 Micro ATX (Socket 939) PCI-Express Motherboard (MB-042-GI)
£44.95 £44.95
GeIL 1GB (2x512MB) PC3200 Value Dual Channel Kit CAS2.5 (GE1GB3200BHDC) (MY-005-GL)
£49.95 £49.95
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA)
£53.95 £53.95
Samsung SH-W162C 16x16 DVD±RW Dual Layer ReWriter (Black) (CD-068-SA)
£19.95 £19.95
Antec Overture II Piano Black Quiet Media case - 450W Smart Power PSU (CA-038-AN)
£66.95 £66.95
Microsoft Remote Keyboard for Windows XP Media Center Edition - Retail (KB-053-MS)
£54.95 £54.95
Hauppauge WinTV PVR-500 Media Centre Edition Dual TV Tuner (GX-028-HA)
£94.95 £94.95
Microsoft Windows XP Media Centre 2005 Edition - OEM - 1Pk (M93-00200) (SW-008-MS)
£64.95 £64.95
Microsoft Windows XP Media Centre 2005 Remote Controller (SW-009-MS)
£18.95 £18.95
Subtotal £544.50
VAT £95.29
Total £639.79
and a 32" LG RZ32LZ55 LCD HD TV for £809
Total £1448.89
28 Mar 2006
looks good personally i like to have 2 drives a smaller one for OS and other programs (because you will gather a few) and the big one for storage.
but like i say thats just a personal preferance, i take it you wont be using this for gaming as i dont see a graphics card are you going to use onboard or do you have one?
1 Jun 2005
Telford
Looks good...I use a 3000+ in my Media Centre and it works well (and stays cool)
Don't see any tuner(s) mentioned?
(edit: ..oops didn't see Hauppauge)
Have you considered using Asus A8N-VM CSM Micro ATX (Socket 939) PCI Express Motherboard (MB-119-AS) (available £49.95 + vat from OCUK :D ) as it uses the better 6150 GPU which I believe is better suited to HDTV?
OP
6 Sep 2005
yeah, i did think about getting another drive, and i may still, depending on money. as for the motherboard, ill have a look at the asus thanks for the tip. and the last note about the analog tuners, i cant receive freeview in this area anyway, for the minute ill use it to run sky through the RF ( i have found out you can run sky though a DVB-S card but you need a card reader as well as a programmer and you have to do some hacking, all way too mcuh for me atm) and ill probably geta dual LNB and another sky box to run freesat through the other input, not the greatest setup i know, wont be able to use any kind of epg, but it will mean i can record off one and view the other at the same time.
if anyone knows a better way of running sky though the pc, please let me know coz im quite new to this.
thanks
18 Sep 2005
Rather than the asus which has a few known problems with USB etc (maybe only on early revision boards though) and doesnt come with all the component/tv out brackets you might want to use in the future ... maybe consider the MSI k8ngm2-FID board. I have one sat here ready to go in my media centre when the chip arrives. They are finally back in stock in a couple of places in the uk. Importantly it uses the 6150 chipset which you'll need for HD.
Marc
OP
6 Sep 2005
to be honest im not to worried about being able to watch HDTV at the mo, i just wanted to make sure that in 12 months down the line, if and when HD is more common place, i dont have to go get a new tv. i can always upgrade the graphics when i want to, although i will look at the msi board mentioned.
