- 7 Sep 2020
- Gods Country
but again theres no hard and fast rule....so for him its obviously ok.You must be blind. No chance is the eye in the middle of the screen when seated there.
The Ceiling is only 4ft height. Its perfect, for me and my borrower familyI do.
Most ergonomics professionalswho says its too high??
oh yeh because the first thing people do when building a media wall is consult an ergonomics professional to make sure its all ok.....Most ergonomics professionals
I mean...lol ....oh yeh because the first thing people do when building a media wall is consult an ergonomics professional to make sure its all ok.....
These aren't cheap to build so a bit of research & planning is recommended.oh yeh because the first thing people do when building a media wall is consult an ergonomics professional to make sure its all ok.....
The existing fireplace is electric anyway so will likely be be replaced with a narrow once, even more so with the examples.These aren't cheap to build so a bit of research & planning is recommended.
200sols is correct about the ideal height and walls just look better with a TV at the right height .
If you don't need to compromise because of an existing fireplace, then don't! To be fair, the examples with the very slim fireplaces keep the height ok, but cabinet space is very limited.
Some things I'd recommend:
- classic lines that won't age e.g. slim shaker which is contemporary but timeless
- if painted, keep.the colours relatively neutral, but doesn't need to be bland! Mix in some real wood finishes if it's a big wall to break things up a bit
- plenty of space around the TV for options to increase TV size in the future
- fairly simple lightng
- mixture of shelving shapes & sizes
Some other things we did that are great were a concealed door in the bookcase, built in centre speaker and oak inserts into some of the shelves to add a bit of a mid century influence.
I went full Chav then. We had a small room i wanted to use for weekend films,sports or just to read as a snug.
could you shareMy TV is setup at eye level... The bottom of the screen is (just checked) 63cm from the floor (where the actual viewable screen starts) and the top of the screen is 70cm above that (46" telly)
Sofa is direct opposite it and it the straight on angle (height wise) is better for me.
