looking to get a (upper) mid range graphics card for my htpc, but its pretty small in there, and heightwise its an issue, only got 15mm from top of pci bracket to where the top of case is
, and loads of the compact cards are to tall, specially when you factor in getting power into the card :/
the 1070 mini oc galax would probably work but i cant find any to buy :/, the zotec/evga/gigabyte all being too tall, is there any others?
length wise im limited to 25cm
case is an antec fusion
, and loads of the compact cards are to tall, specially when you factor in getting power into the card :/the 1070 mini oc galax would probably work but i cant find any to buy :/, the zotec/evga/gigabyte all being too tall, is there any others?
