Mem & CPU upgrade for X58
3 Jun 2005
I'm looking for a mem and CPU upgrade for my P6T Deluxe. Been away from the hardware scene for so long I'm not even sure what's compatible. Full spec is in my sig.
Err unless you go 2nd hand you wont find a CPU that fits your board.
How much RAM do you have now?
its up to yourself,but I remember 12gb needing 1.4v dram/vtt or qpi/vtt
max safe by intel was 1.4v,i only used to run 6gb with 1.35v vtt,but cpu was at 4.2ghz
the 980x hex cores did have slightly better memory controllers
