Hi All just looking for some advice on a memory upgrade. This is the information on what is currently in my machine, as taken from pc wizard
General Information :
DIMM0 (BANK0 ) : 2048 M
DIMM1 (BANK1 ) : 2048 M
Information SPD EEPROM
Manufacturer : Samsung
Part Number : M378B5773C
Serial Number : 214C6D63
Type : DDR3-SDRAM PC3-10
Format : UDIMM (133.35 x
Size : 2048 MB (1 ranks
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) :
Module XMP : No
Width : 64-bit
Error Correction Capabil
Voltage : 1.50v
Prefetch Buffer : 8-bit
Manufacture : Week 35 of
Thermal Sensor : No
Heat Spreader : No
Supported Frequencies :
CAS Latency (tCL) : 6 cl
RAS to CAS (tRCD) : 6 cl
RAS Precharge (tRP) : 6 clocks @
Cycle Time (tRAS) : 17 clocks @ 4
Min TRC : 23 clocks @ 457 MHz, 27
Information SPD EEPROM (DIMM2) :
Part Number : M378B5773CH0-CH9
Serial Number : F14B6D6318E90800
Type : DDR3-SDRAM PC3-10700 (667
Format : UDIMM (133.35 x 15)
Size : 2048 MB (1 ranks, 8 banks
Module SLi Ready (EPP) : No
Module XMP : No
Width : 64-bit
Error Correction Capability (EC..
Voltage : 1.50v
Manufacture : Week 35 of 2010
Thermal Sensor : No
Heat Spreader : No
Supported Frequencies : 457 MHz,
CAS Latency (tCL) : 6 clocks @ 45
RAS to CAS (tRCD) : 6 clocks @ 45
Memory Controller Information :
Memory Controller : System Memory
Error Correction Capability : No
Number of connectors : 4
Max. Module Size : 16384 MB
and if I use the Crucial scan from there website this is what they say will work Memory Type: DDR3 PC3-12800, DDR3 PC3-10600, DDR3 PC3-14900, DDR3 PC3-14400, DDR3 PC3-17000, DDR3 (non-ECC)
Maximum Memory: 16GB
Currently Installed Memory: 4GB
Total Memory Slots: 4
Available Memory Slots: 2
So any advice would be greatly appreciated
Module XMP : No
Width : 64-bit
Voltage : 1.50v
Thermal Sensor : No
Heat Spreader : No
Module XMP : No
Width : 64-bit
Voltage : 1.50v
Thermal Sensor : No
Heat Spreader : No
