If you change your ram frequency down to 266 in the bios, it should effectively be running in sync with the cpu, (355mhz) If it's running stable now though, not really much point![]()
The VCCD (DRAM) Voltage is the vdimm option in BIOS, so it doesn't actually tell you what it's set to. But it won't be too high. Probably 2.0-2.1v.
I'd be happy with what you have![]()
You can tell people you have Micron "Fatbody" ICs on your memory.
Gives a couple of extra E-peen points for sure![]()
