21 Oct 2010 at 10:26 #1 Fenlig Fenlig Associate Joined 21 Apr 2009 Posts 23 Can I use Ram that is 1600mhz in a mobo that only support 1333mhz?
21 Oct 2010 at 12:15 #2 RJC RJC Don Joined 29 May 2005 Posts 29,093 Location Kent Should work fine, the ram will work at the lower speed. What motherboard are you using or looking at?
21 Oct 2010 at 12:39 #3 Fenlig Fenlig Associate OP Joined 21 Apr 2009 Posts 23 You see ive got a extra core 2 and some sticks of ddr3 lying around and want to make use of them. http://www.overclockers.co.uk/showproduct.php?prodid=MB-308-GI
21 Oct 2010 at 12:42 #4 RJC RJC Don Joined 29 May 2005 Posts 29,093 Location Kent They should work fine, with a overclock you may get them to run @ 1600mhz
22 Oct 2010 at 13:58 #5 Stevinchy Stevinchy Associate Joined 16 Dec 2009 Posts 16 RJC said: They should work fine, with a overclock you may get them to run @ 1600mhz Click to expand... This
