Memory foam pillows for Hero
15 Mar 2006
Hi,
I've got a couple of Hero chairs and I find that I like to use the neck pillows but not the lumbar one. The neck pillows feel ever so just that bit high and I was wondering if anyone was able to tell me if the memory foam ones are better or not? Are they thicker/thinner? Are they that much of an upgrade?
Cheers!
Hi,
They are insanely pricey that's for sure
Just use a normal bed pillow and stick a bit of string through it to tie it on?
I'm in this camp too, my gaming chair now uses one of those memory foam pillows you can buy for travelling. £10 well spent!
